So here I am looking for cheap sram. Use to be that 486s and the like used sram chips as cache so they were a good source as nobody really wanted their old motherboards. Now-a-days I can't find any mother boards, not even on craigstlist! So where have all the old motherboards gone? Thin air a guess.
So I'm eye-balling some cmos sram from futurlec and I'm thinking... naw probably not. Where can a girl get sram around here? Where do you get your sram?
small complaint
Re: small complaint
I still have old stock - 2-3 cubic meters of old motherboards. Also, hard drives ( es.SCSI ) and sometimes CDROMs are a good source of fast SRAM if you don't mind SMD packages.
Re: small complaint
cd-roms, huh? I've never desoldered a surface-mount chip so might be good practice.... looks around bin for cd-rom drives.
- westfw
Re: small complaint
http://www.jameco.com seems to still carry the cache-like sram chips, as well as the "low power" chips that were usually used with batteries to get non-volatile memory.
They stopped appearing on motherboards with the pentium (which has internal cache), and 486 or earlier motherboards are getting pretty hard to find, even if you DO find a stash of motherboards. Cisco routers used to use a fair amount of such SRAM as well; the cache-like chips got used for "microcode" storage on the async interfaces in the 2511 series "terminal servers" for instance...
What kind of specs and quantity are you looking for?
- macegr
Re: small complaint
Maybe just buy new SRAM. In the few-tens-of-K range, it's really cheap. Microchip even has some new SRAM out that interfaces over SPI, saves you a lot of pins if you have an application that needs a lot of rewritable storage that won't degrade after 100,000 writes.
Re: small complaint
wow, thanks for the jameco link! This looks nice, little pricey, but nice.
http://www.jameco.com/webapp/wcs/stores ... tId=242448&
- amberwolf
Re: small complaint
I'm not sure if I still have them, but I might have a box full of those old ISA memory boards, with rows of socketed DIP SRAM chips. Most were from 8-bit ISA systems, so they'd be pretty small chips, but there was at least one of them that used the (I think) 6116 SRAM chip, 2Kx8bit IIRC, with several rows.
I also am pretty sure I still have an old STB video card with socketed SRAM chips totalling 1MB, in 8 chips, so probably 1Mbit each. They were a form of SIP, with interleaved pins making two very closely spaced rows.
Re: small complaint
wow, amberwolf. Name your price. The ram on the video card sounds very nice.
- amberwolf
Re: small complaint
If I find it (which might take a while), you can have it for whatever shipping would be to you from 85051. I suspect it'd all fit in a USPS flat rate box, boards and all, in ESD bags with padding (if I have any left, I'd use the paper stuff I got last time I ordered parts from Mouser/etc). If you happen to have any lightweight bike parts laying around, or high-brightness red LEDs I can use for taillights/brakelights, things like that, I wouldn't be averse to a trade, but it's not necessary. I'm never going to use this stuff, and someone that will ought to have it (it's how I get almost everything I use, especially the stuff on my Electricle™bike project).
Keep in mind that it's probably been at least 10 years since I've seen this stuff, much less actually had it in a working computer. So I couldnt' guarantee any of them working (or even that I still have them in a findable spot!).
