powering a Lipro charge controller by a hand cranked generator
Post test messages here
joel neumann
Post by joel neumann »
Knowlegable Electronic Eng.
after reading the information on the Lipro battery charge controller ca the charge controller be used for a hand cranked generator. It seems to fallow the same format in that the generator may fluxuate in voltage output but will provide a sum what steady output.
john444
Re: powering a Lipro charge controller by a hand cranked generator
Post by john444 »
Hi Joel,
As long as you don't let the input voltage go over 6-V,
It should work great.
It will take a lot of cranking though.
Good luck, John
Return to “Test Message Forum (closed)”
