i have some problems with the shield that I bought few days ago.
1) one chip looks like broken, it is possible see an hole on its surface.
http://www.ruggerocastagnola.com/docs/P1070308.JPG
2) with the multimeter is possible to see that poles are connected to one another and to ground as well, is it normal?
http://www.ruggerocastagnola.com/docs/P1070304.JPG
http://www.ruggerocastagnola.com/docs/P1070305.JPG
Thank you.
Problems with motor shield Kit v2.0 pins connection
Re: Problems with motor shield Kit v2.0 pins connection
Looks like the H-brige chip was overloaded. Sometimes they fail 'open circuit' and sometimes closed. Looks like yours was the latter failure mode. What were you using for a motor and power supply?
I used two stepper motors for 2.5A each (NEMA 17) and 11V power supply (controlled by multimeter). I followed this instruction: http://learn.adafruit.com/adafruit-moto ... ll-headers
This controller is only rated for 1.2A per channel. http://www.adafruit.com/products/1438#DescriptionI used two stepper motors for 2.5A each
ok, thank you for the help
