Problem with 2.8'' PiTFT Touch Screen
Post test messages here
nhazliza
Post by nhazliza »
On my PI I have installed the current available 2014-01-07-wheezy-raspbian image.
I have installed the software step by step as you described in your homepage.
During installation - everything is working well
After these steps:
sudo modprobe spi-bcm2708
sudo modprobe fbtft_device name=adafruitts rotate=90
export FRAMEBUFFER=/dev/fb1
startx
Whenever I type the startx command my desktop display is frozen on a black screen
adafruit_support_rick
Re: Problem with 2.8'' PiTFT Touch Screen
Yes, that command switches the Pi to use the PiTFT instead of the desktop display. It doesn't run both displays
Return to “Test Message Forum (closed)”
