Hello, I am working on a agriculture application, the machine should drive at a speed of 700 mtr/hour.
This should be controlled by the gps receiver and a Arduino Nano.
As a test I use the following code:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample code demonstrates just about every built-in operation of TinyGPS++ (TinyGPSPlus).
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 3, TXPin = 2;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
void setup()
Serial.begin(115200);
ss.begin(GPSBaud);
Serial.println(F("GPS motor driver.ino"));
Serial.println(F("by Rien Brand"));
Serial.println();
float Speedval=0;
void loop()
// Dispatch incoming characters
while (ss.available() > 0)
gps.encode(ss.read());
if (gps.speed.isUpdated())
Speedval = (gps.speed.value());
Serial.print(F("SPEED km/h="));
Serial.println(gps.speed.kmph());
Serial.print(F(" Speedvalue "));
Serial.println(Speedval);
else if (millis() - last > 5000)
Serial.println();
if (gps.location.isValid())
Serial.print(F("DIAGS Chars="));
Serial.print(gps.charsProcessed());
Serial.print(F(" Sentences-with-Fix="));
Serial.print(gps.sentencesWithFix());
Serial.print(F(" Failed-checksum="));
Serial.print(gps.failedChecksum());
Serial.print(F(" Passed-checksum="));
Serial.println(gps.passedChecksum());
if (gps.charsProcessed() < 10)
Serial.println(F("WARNING: No GPS data. Check wiring."));
last = millis();
Serial.println();
This works well, but only when I drive first say 3 km/hour and then reduce the speed until the desired speed of 700mtr/uur.
If I start to drive with a lower speed than 1 km/hour, the indicated speed is approximately zero.
Does anyone have an idea?
Regards,
Rien
Ultimate GPS
- adafruit_support_rick
Re: Ultimate GPS
Does the speed ever become accurate, or does it remain 0 for as long as you drive?
- Rien
Re: Ultimate GPS
As long as I drive below the 1 km the value stay to 0 -0.04 km, when I increase the speed to 2 km then the value become accurate even when I decrease the speed below the 1km.
If I start to drive again from 0 km the same happend, I have tried with reset the arduino, the GPS module and the seriele monitor with the same results.
Re: Ultimate GPS
This may b a limitation of the onboard speed algorithm. You may have to develop your own algorithm. However, at such slow speeds, the inherent positional inaccuracies may make this difficult.
- Rien
Re: Ultimate GPS
Hi, In the mean time I have tried the Venus GPS receiver with the same results, so I think I am on the end with the GPS posibilities.
Thanks for your help.
Regards,
Rien
Regards,
Rien
- Rien
Re: Ultimate GPS
Hy, can someone help to set the Nav Speed threshold, or better disable them. I have the command packet for this ($PMTK,0*3F<CR><LF>) but how can I use this in the code?
Re: Ultimate GPS
That doesn't look like a complete PMTK command. There should be a number after "PMTK" and before the comma, like this:
"$PMTKnnn,0*3F"
The way you send a PMTK command is with the gps.sendCommand function:
gps.sendCommand("$PMTKnnn,0*3F");
"$PMTKnnn,0*3F"
- Rien
Re: Ultimate GPS
Then I recieve a error: 'class TinyGPSPlus' has no member named 'sendCommand'
Can I use a additional liberary to resolve this?
Nou I see the problem, it must be: GPS.sendCommand("$PMTKnnn,0*3F");
Re: Ultimate GPS
OK - I looked up the Set Nav Speed Threshold command. The command number is 397, so to disable it, you would send
"$PMTK397,0*23"
"$PMTK397,0*23"
- Rien
Re: Ultimate GPS
With the TinyGPS Lib the
ss.println("$PMTK397,0*23");
command work correct
Now I have the correct speed from start (without delay) to 1Kpm, very nice!
Thanks for help!!
Rien
Thanks for help!!
Rien
- Rien
Re: Ultimate GPS
Hi, I have still a problem, with the extarnal antenna I had to first move faster than 1,3 km/hour, If I then reduce the speed I get the right value, after a short break, the problem repeated itself.adafruit_support_rick wrote:Nice!
But if I use the GPS unit without the external antenna I get direct a correct value from 0-700Mtr/uur, Is it possible that the external antenna cable are to long or do search for a better antenna ?
Thanks for help,
Rien
Re: Ultimate GPS
Maybe you need a better antenna. Do you get fewer satellites with the antenna?
- Rien
Re: Ultimate GPS
Today I have a FGPANE Series antenna purchased at GlobalTop, I hope this work.
There is no difference in the number of satellites, with or without the included external antenna.
I have asked the GTop engineer but have no answer on my question or the lengt of the antenna wire make the difference.
Be continued!
Be continued!
