Hi there,
I just received this Soft Potentiometer for a project I'm woking on. Hooked it up to an Arduino leonardo as shown below (pin 1 to 3.3v, pin 2 to analog in, pin 3 to GND) and it got hot. Like really hot. I've unplugged and stopped there. Is/was it a faulty potentiometer? It now looks a little worse for wear.
Hot Pot
Re: Hot Pot
When you press on the gap between the high and low side, you create a short circuit which will heat up if it is connected directly between power and ground. The usage instructions specify wiring with series resistors to limit the current.
https://www.adafruit.com/product/1069
To use Connect one side pin to ground via a 10K resistor in series. Connect the other side pin to your Vcc power line (3V, 5V etc) via a different 10K resistor in series. Then read the analog voltage on the center pin. It will range from 1/3 Vcc to 2/3 Vcc . Do not connect to Ground and Power directly!
