I have few questions about powering up a 60 LEDs NeoPixel strip.
- If I use a 1000 µF - 10V it will work ?
- At the moment I don't have the 5V - 3.5A power cable that is needed, I have only a 5V - 2A power cable: it will work with a reduced brightness/response time or it won't work at all ?
Powering NeoPixel LEDs Strip
Re: Powering NeoPixel LEDs Strip
Yes, that should be fine.- If I use a 1000 µF - 10V it will work ?
It will work. You just won't be able to drive all pixels to full brightness at the same time.I don't have the 5V - 3.5A power cable that is needed, I have only a 5V - 2A power cable: it will work with a reduced brightness/response time or it won't work at all ?
- Giacomo_Verri
Thank you so much! :)
- Giacomo_Verri
I need another little help: I can't find a power cable that fits the requested specifics (5v @ 3.5A), were can I search for ? I need that can be shipped to Italy!
This 5v/4A one should work for you: https://www.adafruit.com/products/1466
It comes with a US style plug, but can run on up to 240VAC.
- Giacomo_Verri
Thank's a lot! Now I can jump into the fantastic world of NeoPixels!
