Product 1828 Type A USB Female Connector
Post test messages here
innerlight
Post by innerlight »
I just got a Type A female USB connector (Product 1828). It says it press fits into the plastic holder. It does not. When I put it in it just falls back out (loose). Is there a way to put this together where it stays in tight?
Franklin97355
Re: Product 1828 Type A USB Female Connector
Post by Franklin97355 »
Can you post a picture of the connector and it's cable?
innerlight
Franklin97355
Could you post a picture of your connector? (I've seen the one on the product page)
okuda
Post by okuda »
There is the same question.
How do I fix the connector in case you doing?
Franklin97355
What seems to be wrong with your connector?
okuda
Post by okuda »
Connector is not fixed to the case.
adafruit_support_mike
Try putting everything on a cable.
The plug should make a friction fit on the cable, pushing the shroud up against the terminator and holding it in place.
okuda
Post by okuda »
If you connect the cable while, I think if you disconnect the USB plug jack comes out from the case.Without resistance.
jes
Post by jes »
Same problem with the male part - something is certainly wrong with this "design"
adafruit2
Post by adafruit2 »
hiya, we just grabbed some and it looks like the plastic casing is a little bigger this time than last! we'll contact the factory but don't expect to get replacements for a few weeks at least. for now, you can perhaps use epoxy to make the connector fit in better. if you can't use the connectors, email support@adafruit for a refund.
okuda
Post by okuda »
All right. Please reply by e-mail if there is contact from the factory.
Please have this time to refund.
Return to “Test Message Forum (closed)”
