If I try to compile the fresh downloaded sketch "talking click", I always get the following error-message:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Arduino.h:235,
from TalkingClock.ino:40:
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:40: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:41: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:42: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:43: error: expected unqualified-id before numeric constant
What can I do. How is ist possible, that a fresh downloaded sketch doesn´t run.
Please, help me!
Many thanks for your answer.
mfg mammut
talking clock -sketch doesn´´t rund-
- adafruit_support_rick
Re: talking clock -sketch doesn´´t rund-
I've seen this before where the downloaded sketch contains line numbers. Use the 'copy code' button in the upper right hand corner of the code window to copy the code.
- mammut2806
Thank You for your answer. I downloaded the ketch "Adafruit-Talking-Clock" from GitHub, also the needed librarys. Then I load the sketch in the "Arduino IDE" and start to compile. This is the point, where I get the error-message (see my first post).
mfg mammut2806
mfg mammut2806
please post the sketch here
- mammut2806
in the meantime I found the error!
Many thanks for your helping.
mfg mammut 2806
mfg mammut 2806
