[quote]
[color=#7E7E7E]//adafruit gps ultimate shield and 20x4 lcd I2C[/color]
#include <Adafruit_GPS.h>
#include <[color=#CC6600]SoftwareSerial[/color].h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]LiquidCrystal_I2C[/color].h>
[color=#CC6600]LiquidCrystal_I2C[/color] lcd(0X27);
[color=#7E7E7E]// Connect the GPS Power pin to 5V[/color]
[color=#7E7E7E]// Connect the GPS Ground pin to ground[/color]
[color=#7E7E7E]// If using software serial (sketch example default):[/color]
[color=#7E7E7E]// Connect the GPS TX (transmit) pin to Digital 3[/color]
[color=#7E7E7E]// Connect the GPS RX (receive) pin to Digital 2[/color]
[color=#7E7E7E]// If using hardware serial (e.g. Arduino Mega):[/color]
[color=#7E7E7E]// Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3[/color]
[color=#7E7E7E]// Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3[/color]
[color=#7E7E7E]// If you're using the Adafruit GPS shield, change [/color]
[color=#7E7E7E]// SoftwareSerial mySerial(3, 2); -> SoftwareSerial mySerial(8, 7);[/color]
[color=#7E7E7E]// and make sure the switch is set to SoftSerial[/color]
[color=#7E7E7E]// If using software serial, keep this line enabled[/color]
[color=#7E7E7E]// (you can change the pin numbers to match your wiring):[/color]
[color=#CC6600]SoftwareSerial[/color] mySerial(8, 7);
[color=#7E7E7E]// If using hardware serial (e.g. Arduino Mega), comment out the[/color]
[color=#7E7E7E]// above SoftwareSerial line, and enable this line instead[/color]
[color=#7E7E7E]// (you can change the Serial number to match your wiring):[/color]
[color=#7E7E7E]//HardwareSerial mySerial = Serial1;[/color]
Adafruit_GPS GPS(&mySerial);
[color=#7E7E7E]// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console[/color]
[color=#7E7E7E]// Set to 'true' if you want to debug and listen to the raw GPS sentences. [/color]
#define GPSECHO [color=#CC6600]true[/color]
[color=#7E7E7E]// this keeps track of whether we're using the interrupt[/color]
[color=#7E7E7E]// off by default![/color]
[color=#CC6600]boolean[/color] usingInterrupt = [color=#CC6600]false[/color];
[color=#CC6600]void[/color] useInterrupt([color=#CC6600]boolean[/color]); [color=#7E7E7E]// Func prototype keeps Arduino 0023 happy[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
lcd.[color=#CC6600]begin[/color] (20,4);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]begin[/color](9600);
[color=#7E7E7E]// when characters arrive over the serial port...[/color]
[color=#CC6600]if[/color]([color=#CC6600][b]Serial[/b][/color].[color=#CC6600]available[/color])
[color=#7E7E7E]// wait a bit for the entire message to arrive[/color]
[color=#CC6600]delay[/color](100);
[color=#7E7E7E]// clear the screen[/color]
lcd.[color=#CC6600]clear[/color]();
[color=#7E7E7E]// read all the available characters[/color]
[color=#CC6600]while[/color] ([color=#CC6600][b]Serial[/b][/color].[color=#CC6600]available[/color]() > 0)
[color=#7E7E7E]// display each character to the LCD[/color]
lcd.[color=#CC6600]write[/color]([color=#CC6600][b]Serial[/b][/color].[color=#CC6600]read[/color]());
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color]([color=#006699]"Adafruit GPS library basic test!"[/color]);
[color=#7E7E7E]// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800[/color]
GPS.[color=#CC6600]begin[/color](9600);
[color=#7E7E7E]// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude[/color]
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
[color=#7E7E7E]// uncomment this line to turn on only the "minimum recommended" data[/color]
[color=#7E7E7E]//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);[/color]
[color=#7E7E7E]// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since[/color]
[color=#7E7E7E]// the parser doesn't care about other sentences at this time[/color]
[color=#7E7E7E]// Set the update rate[/color]
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); [color=#7E7E7E]// 1 Hz update rate[/color]
[color=#7E7E7E]// For the parsing code to work nicely and have time to sort thru the data, and[/color]
[color=#7E7E7E]// print it out we don't suggest using anything higher than 1 Hz[/color]
[color=#7E7E7E]// Request updates on antenna status, comment out to keep quiet[/color]
GPS.sendCommand(PGCMD_ANTENNA);
[color=#7E7E7E]// the nice thing about this code is you can have a timer0 interrupt go off[/color]
[color=#7E7E7E]// every 1 millisecond, and read data from the GPS for you. that makes the[/color]
[color=#7E7E7E]// loop code a heck of a lot easier![/color]
useInterrupt([color=#CC6600]true[/color]);
[color=#CC6600]delay[/color](1000);
[color=#7E7E7E]// Ask for firmware version[/color]
mySerial.[color=#CC6600]println[/color](PMTK_Q_RELEASE);
[color=#7E7E7E]// Interrupt is called once a millisecond, looks for any new GPS data, and stores it[/color]
SIGNAL(TIMER0_COMPA_vect) {
[color=#CC6600]char[/color] c = GPS.[color=#CC6600]read[/color]();
[color=#7E7E7E]// if you want to debug, this is a good time to do it![/color]
#ifdef UDR0
[color=#CC6600]if[/color] (GPSECHO)
[color=#CC6600]if[/color] (c) UDR0 = c;
[color=#7E7E7E]// writing direct to UDR0 is much much faster than Serial.print [/color]
[color=#7E7E7E]// but only one character can be written at a time. [/color]
#endif
[color=#CC6600]void[/color] useInterrupt([color=#CC6600]boolean[/color] v) {
[color=#CC6600]if[/color] (v) {
[color=#7E7E7E]// Timer0 is already used for millis() - we'll just interrupt somewhere[/color]
[color=#7E7E7E]// in the middle and call the "Compare A" function above[/color]
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = [color=#CC6600]true[/color];
} [color=#CC6600]else[/color] {
[color=#7E7E7E]// do not call the interrupt function COMPA anymore[/color]
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = [color=#CC6600]millis[/color]();
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#7E7E7E]// in case you are not using the interrupt above, you'll[/color]
[color=#7E7E7E]// need to 'hand query' the GPS, not suggested :([/color]
[color=#CC6600]if[/color] (! usingInterrupt) {
[color=#7E7E7E]// read data from the GPS in the 'main loop'[/color]
[color=#CC6600]if[/color] (c) [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](c);
[color=#7E7E7E]// if a sentence is received, we can check the checksum, parse it...[/color]
[color=#CC6600]if[/color] (GPS.newNMEAreceived()) {
[color=#7E7E7E]// a tricky thing here is if we print the NMEA sentence, or data[/color]
[color=#7E7E7E]// we end up not listening and catching other sentences! [/color]
[color=#7E7E7E]// so be very wary if using OUTPUT_ALLDATA and trytng to print out data[/color]
[color=#7E7E7E]//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false[/color]
[color=#CC6600]if[/color] (!GPS.parse(GPS.lastNMEA())) [color=#7E7E7E]// this also sets the newNMEAreceived() flag to false[/color]
[color=#CC6600]return[/color]; [color=#7E7E7E]// we can fail to parse a sentence in which case we should just wait for another[/color]
[color=#7E7E7E]// if millis() or timer wraps around, we'll just reset it[/color]
[color=#CC6600]if[/color] (timer > [color=#CC6600]millis[/color]()) timer = [color=#CC6600]millis[/color]();
[color=#7E7E7E]// approximately every 2 seconds or so, print out the current stats[/color]
[color=#CC6600]if[/color] ([color=#CC6600]millis[/color]() - timer > 2000) {
timer = [color=#CC6600]millis[/color](); [color=#7E7E7E]// reset the timer[/color]
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"\nTime: "[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.hour, [color=#006699]DEC[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]':'[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.minute, [color=#006699]DEC[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]':'[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.seconds, [color=#006699]DEC[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]'.'[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.milliseconds);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Date: "[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.day, [color=#006699]DEC[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]'/'[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.month, [color=#006699]DEC[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"/20"[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.year, [color=#006699]DEC[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Fix: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](([color=#CC6600]int[/color])GPS.fix);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]" quality: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](([color=#CC6600]int[/color])GPS.fixquality);
[color=#CC6600]if[/color] (GPS.fix) {
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Location: "[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.latitude, 4); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.lat);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]", "[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.longitude, 4); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.lon);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Location (in degrees, works with Google Maps): "[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](GPS.latitudeDegrees, 4);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.longitudeDegrees, 4);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Speed (knots): "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.[color=#CC6600]speed[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Angle: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.angle);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Altitude: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](GPS.[color=#CC6600]altitude[/color]);
[color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Satellites: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](([color=#CC6600]int[/color])GPS.[color=#CC6600]satellites[/color]);
[/quote]
