The RaspberryPi 2 I purchased from you on 2015-03-04 order number 727103-9442390639 does not boot.
I have read these forums and have tried the things mentioned here but still no boot, just the color screen display is shown. I assume that screen is coming from the HDMI driver board and not the RaspberryPi. The HDMI board and LCD display came from Adafruit too. The LCD display works fine with my other Pi's, A, A+, B, B+. No other Pi has given me any problems, just the Pi 2.
My experience with RaspberryPi computers dates back to December 2013, so I know how to handle SD and micro SD cards and Pi's. A RaspberryPi has been monitoring the solar electric systems since 2014-06-01 with a bash script that I wrote. It uses A/D converters from your store too. My point is: I know my way around a RaspberryPi and Linux so you can talk technical with me.
What would be my next step to remedy the problem?
Thank you for your consideration.
Gregg
RaspberryPi 2 model B no boot
- adafruit_support_mike
Re: RaspberryPi 2 model B no boot
Are you using the latest version of Rasbian?
The v2 has a new microprocessor and only versions of the OS released since the beginning of 2015 will work with it.
- gregg_scholfield
Thank you Mike. I will give that a try. I'll download the latest from RaspberryPi.org.
Gregg
Gregg
