Question about 220 to 110 volt power converters
Post test messages here
joshcovert
Post by joshcovert »
I want to buy a German analog synth, but it is designed for 220 v, so to use it here in the U.S., I could just use a voltage converter, right? I just want to make sure I won't fry any expensive circuits.
-Josh
Re: Question about 220 to 110 volt power converters
Post by adafruit »
yup, you want a transformer power converter
Stoney3K
Post by Stoney3K »
Transformer converter is the way to go, however...
If it's a recent synth, check the back of the unit to see if it accepts 110V/60Hz. Most recent electronic devices will accept a range of voltages from 100V to 240V without hassle, but IT SHOULD BE MARKED ON THE UNIT. (Putting this in caps to make sure you check ;))
If it's an older unit (pre-1990s), go for the transformer option. If it's a more recent unit, check the voltage rating sticker on the unit (near the power inlet), you might be able to get away with a US to EU adapter plug. When in doubt, get a transformer.
Return to “Test Message Forum (closed)”
