Adafruit servo tutorial for raspberry pi
by gheciobanu on Mon Feb 03, 2014 8:39 pm
I tried doing the servo tutorial and it worked, then i cleaned everything off my breadboard and did another project then when i went back to my servo and plugged everything back in the bread board the terminal window said Error writing to: servo value: (here go numbers from 0 to 179) What can i do i checked if the battery pack is working and it does work! Please help what can i do?? :(
gheciobanu
Re: Adafruit servo tutorial for raspberry pi
by adafruit_support_rick on Tue Feb 04, 2014 11:12 am
Check your wiring again.
by gheciobanu on Sun Feb 09, 2014 10:13 pm
i did over and over again.
servo black goes to breadboard negative,
servo red goes to breadboard positive,
servo white goes to pin 18 on cobbler,
batter pack black goes to breadboard negative,
batter pack red goes to breadboard red,
pi cobbler GND pin goes to bread board negative.
i checked everything, is there anything else that i might be doing wrong?
gheciobanu
by adafruit_support_bill on Mon Feb 10, 2014 6:04 am
The wiring sounds right. From the error message you are getting, I suspect it is a software problem. Are you running occidentalis?
by gheciobanu on Mon Feb 10, 2014 4:46 pm
Yes the newest version of occidentals, and the funny thing is that i wired it and it worked, then i restarted the pi and the i ran the script again that's the message i was getting, and i tried deleting the script and making a new one, ans i still got the error message.
gheciobanu
by adafruit_support_mike on Mon Feb 10, 2014 6:46 pm
Let's see.. that error message shows up when the script can't open /sys/class/rpi-pwm/pwm0/, and errors like that are usually permissions problems.
Are you using `sudo` to invoke the script?
by gheciobanu on Mon Feb 10, 2014 11:14 pm
in the tutorial it says to do python servo.py, but i also tried doing sudo servo.py and sudo ./servo.py and when i do sudo it says command not found, but when i do python servo.py it gives me the error servo value
gheciobanu
by adafruit_support_rick on Tue Feb 11, 2014 9:20 am
Try sudo python servo.py
by gheciobanu on Tue Feb 11, 2014 3:26 pm
I still get the same error message as if i did python servo.py
screenshot of error
gheciobanu
by adafruit_support_mike on Wed Feb 12, 2014 2:44 pm
Let's check the GPIO path:
What do you get from the following commands?
ls -l /sys/
ls -l /sys/class/
ls -l /sys/class/rpi-pwm/
by gheciobanu on Wed Feb 12, 2014 3:57 pm
I got some information about some files, i attached a screenshot of my ssh window
gheciobanu
by adafruit_support_mike on Thu Feb 13, 2014 3:12 pm
That's the information I was looking for. According to those directory listings, you no longer have kernel support for PWM.
It would probably be easiest to get it back by installing a fresh version of Occidentalis on your SD card.
by gheciobanu on Thu Feb 13, 2014 3:14 pm
OK, ill uninstall and install it again, but why did that happen?
gheciobanu
by adafruit_support_mike on Sun Feb 16, 2014 2:46 pm
There are too many possibilities to say right now. You'd need to repeat everything you did after disconnecting the first servo experiment and check at each step to see if PWM support is still there.
