ORDER #599334-7245253740
hi
I just got this item today
it is not working !!
when I connected it to 5v
the multimeter reading is 5v
then got some object pass by sensor supposed
this 5v changes >> less reading
but it didn't change it remans 5v all the time
there is something wrong with it
I want to return it and get new one which works perfectly
thanks
ir distance sensor return
- Franklin97355
Re: ir distance sensor return
Could you post clear pictures of your board and the connections to it? And the product number.
- adafruit_support_bill
Which model sensor are you referring to?
Please post photos showing how you have it connected to your circuit.
- janowh
the model I used is
IR distance sensor includes cable (10cm-80cm) - GP2Y0A21YK0F
I used the circuit showing in the attachment >> the sensor didn't work
I previously used same sensor same model 2 weeks ago for the same circuit it did work
but for the new sensor there is no signal detection at all
- Attachments
- sensor wiring.png (60.88 KiB) Viewed 352 times
- Franklin97355
Please email [email protected] with a link to this thread for a replacement
