I bought a raspberry pi B (invoice #565472)and later a B+ form you. My B stopped working last night mysteriously where it won't boot at all even when I have tried multiple SD cards with raspbian. The Red light is solid on so power is good but the green light does not flash at all.
So I thought I to use the back up B+ for my project but I appear to have a faulty raspberry pi b+
The SD card slot doesn't keep the card in and in fact it ejects the card. I just discovered as it is the first time I opened the box to check.
How can I return for a replacement since it is obviously a manufacturing fault? Invoice #615167 for Pi B+
I am not sure what you can do for my original Pi B as well?
Raspberry Pi B+SD card slot not hold SD card in out of box
- ajitk
- Franklin97355
Re: Raspberry Pi B+SD card slot not hold SD card in out of b
Adafruit has a 30 day warranty on products we sell. You should verify everything is working when you get it. That being said, if you email [email protected] with a link to this thread they may be able to work something out with you.
- ajitk
Hi
Thanks for the response, I have sent an email to support.
