Powerboost defective
- wellsa
How can I get a refund? I have re-ordered a unit (ie cross-ship 692869-3245198613) and need to get a refund on the defective unit. I ordered it on 1/12/2015 # 680070-7419441477 ($14.95). It worked for a day, now it gets very very hot. After re-looking, the solder joints are good, but the +ve and -ve are showing they are connected somewhere. I have pictures showing the clean solder joints if necessary.
Re: Powerboost defective
Please do post photos. It will help us approve the replacement.
- wellsa
2 files posted.
- Attachments
- pb2.jpg (115.61 KiB) Viewed 734 times
- pb1.jpg (113.89 KiB) Viewed 734 times
Thank you.
The joints do look good. What resistance do you see between the + and - pads?
- wellsa
Nothing else was added, just the 2 components I mentioned before. It was coupled with the solar charger kit I bought from you, It worked fine for a day and a bit, powered my Pi just fine until it broke.
I understand that. My question was for the sake of double-checking the cause of failure and correlating it with other failures we've seen.
You mentioned seeing a low resistance. What was the value?
- wellsa
I didn't mention low resistance. Not sure what u r asking.
- wellsa
If there is something u want me to test please let me know. Thanks.
From your first post:
That sounds like a known issue, and if you can give me the resistance between +ve and -ve I can probably approve a replacement.wellsa wrote:After re-looking, the solder joints are good, but the +ve and -ve are showing they are connected somewhere.
- wellsa
The number is not constant, about 7 is the norm, pic attached.
- Attachments
- 20150201_132505.jpg (115.07 KiB) Viewed 618 times
Thank you. That's within the expected range.
Send a note to [email protected] with a link to this thread and the folks there will get you a replacement (#2030).
