Id like to try making my own wing design for my Feather. But I don't see the eagle files anywhere. I see the Fabrication print on the product page with dimensions. If the file is not available yet can I get the dimension for how far apart the 12 and 16 pin rows are from the edge of board. I'm assuming the pins are 2.54mm from each other from the center.
I have attached the picture of the spec I'm looking for with an lime green arrow in case I wasn't good at explaining.
Adafruit Feather eagle files
- Keebie81
- adafruit_products_fabprint.png (298.48 KiB) Viewed 1684 times
- adafruit2
Re: Adafruit Feather eagle files
heya! its 0.05" but it might be easier to use our FeatherWing object - just added to our eagle lib :)
https://github.com/adafruit/Adafruit-Eagle-Library
- Keebie81
awesome! thanks for the quick reply and putting the FeatherWing in there.adafruit2 wrote:heya! its 0.05" but it might be easier to use our FeatherWing object - just added to our eagle lib :)
- stevenrice
Hi there, i was looking at the feather board to user it for a project but does it have an ability for an on and off switch smililar to the lipo back pack for trinket and bluefruit micro??
Nope. You'd have to add a switch (which you could do in the baseline Feather's prototyping area).
- stevenrice
Thanks mike I figured that was the case.
