IC problem
MiniPOV4 and previous versions
hantheidiot1234
IC problem
Post by hantheidiot1234 »
hi, i'm new to this forum and i have a question to ask
I am making a minipov 3 DIY
"i put the microcontroller in the socket and soldered it on to the board, does it matter?"
s133p
Re: IC problem
Post by s133p »
The answer should be a resounding maybe. If the uC still works, then its fine. if not, you will need a new one. However, it is highly likely that it is fine, unless you really heated the pin a LOT when soldering it.
hantheidiot1234
Re: IC problem
Thx alot :D
Return to “MiniPOV”
