microcontroller
MiniPOV4 and previous versions
hantheidiot1234
microcontroller
Post by hantheidiot1234 »
Can i use a different microcontroller for the minipov3?
s133p
Re: microcontroller
Post by s133p »
If you want to build your own board and do a DIY version then you can use any microcontroller with enough pins. However you would need to program it from scratch and make the design compatible with the pinout of your chip. And at that point it is debate able if it is still even a "MiniPOV". Hope that helps.
P.S. If you do decide to design and code your own version the people of these forums my be able to assist you in making it work, but it wont be "supported" in the same way the kit version is. Just a heads up!
Return to “MiniPOV”
