PROGRAMMING HELP
MiniPOV, MiniPOV2 and MiniPOV3
PROGRAMMING HELP
Postby Jevanko » Sun Nov 29, 2009 11:32 pm
ok so i am trying to program my minipov kit using the alt leds program and i get the out of terminal
jmevanko$ make program-alt_leds
make: *** No rule to make target `program-alt_leds'. Stop.
how do i fix this? im using a mac
-Jason
Jevanko
Re: PROGRAMMING HELP
Postby adafruit » Sun Nov 29, 2009 11:41 pm
you're not in the right directory. go to the directory where the Makefile and .c are
Postby Jevanko » Mon Nov 30, 2009 11:19 am
how do i do that?
Jevanko
Postby Jevanko » Mon Nov 30, 2009 4:54 pm
it worked! thank you. just one more question. how do i compile a file to burn onto the chip? im doing the brain machine kit and i can't figure it out
Jevanko
Postby adafruit » Mon Nov 30, 2009 5:01 pm
you can rename the .c file to mypov.c (easiest)
or you can edit the makefile to add a new .hex file to the list of those made (tougher)
Postby Jevanko » Mon Nov 30, 2009 5:07 pm
which file do i change to mypov.c? there are a ton of .c files in the minipov firmware folder
Jevanko
Postby mtbf0 » Mon Nov 30, 2009 6:20 pm
Jevanko wrote:which file do i change to mypov.c? there are a ton of .c files in the minipov firmware folder
the file slm.c from the zip file with the brainwave firmware in it.
mtbf0
Postby Jevanko » Mon Nov 30, 2009 6:42 pm
ok, sorry for all the questions but im new to the whole programing thing. After i change the name of that file i use terminal to transfer it to the board?
Jevanko
Postby adafruit » Mon Nov 30, 2009 7:16 pm
you may want to read the article about the brainwave machine in detail. it probably has step-by-step instructions?
Postby Jevanko » Mon Nov 30, 2009 7:27 pm
it does, but for PC. would these work for mac?
Jevanko
Postby adafruit » Mon Nov 30, 2009 7:28 pm
well you should try first, no?
Postby Jevanko » Mon Nov 30, 2009 7:52 pm
ok so i did all that and it worked except it gave me an error.
avrdude: erasing chip
avrdude: reading input file ""
avrdude: error opening : No such file or directory
avrdude: input file auto detected as invalid format
avrdude: can't open input file : No such file or directory
what caused this?
Jevanko
Postby mtbf0 » Mon Nov 30, 2009 10:29 pm
did you compile the program?
without screenshots i have to imagine what you're doing.
did you put slm.c in the directory with the minipov3 firmware?
did you rename slm.c to mypov.c as in the discussion above.
if so
make program-mypov
ought to do the trick for you.
or, if you just unzip mitch's file and cd into the directory you put it in
make program-slm
should get you there.
mtbf0
Postby Jevanko » Fri Dec 04, 2009 10:35 pm
so i tryed to reprogram my chip because it wasn't working, and now its giving me a whole new error. i am "cd" in the correct file.
screen.tiff
screen.tiff (37.3 KiB) Viewed 3041 times
Jevanko
Next
Return to MiniPOV
Users browsing this forum: No registered users and 2 guests
New Products [103]
LEDs[109]
Cables[61]
