I built a minipov 2 from the kit. I realize now that life would be easier if I had gotten the 3 but here I am.
I am getting the sequential flash, so I think I have assembled the kit porperly. My PC didn't have a parallel port so I scrounged up a PCI parallel card.
I believe my entire problem in that I am running XP 64. GiveIO will not install, with the BAT file giving the following error:
starting giveio... start failed (status 1275):
This driver has been blocked from loading
(avrdude-gui install of giveIO yields the same error)
My research seems to say the it is a 32 bit driver and isn't compatible with XP 64.
Is there any workaround that will enable me to actually program my minipov 2 or did I assemble a sequentially blinking paperweight?
MiniPOV 2 xp64 giveio issue
Re: MiniPOV 2 xp64 giveio issue
sounds like a bad driver do you have access to any machines with a parallel port?
- ckigar
thanks for the response...
It works fine on my workstation at work, so I think I diagnosed (32 bit vs 64 bit) correctly. I'm going to set this one aside and mess around with some other stuff on the bench...
well, you can program it at work at least
