Speed up display (faster blinks)
I understand you can decrease the display speed by increasing the prescalar. Is there a way to speed up your display? Also there seems to be only set prescalars. Is it not fully adjustable? I need to adjust it for a rotating display at 800rpm with the outer led at about 4.5in radius and inner led at 2.75in. Any help would be useful. Thanks!
Re: Speed up display (faster blinks)
to speed up the display decrease the constant in the following line of code.
there are comments in the code that describe the math.
OCR1A = (uint16_t)10000;
