Static PoV
Static PoV
by josekiamora on Wed Apr 20, 2011 4:31 am
Hello
I want to make a static pov that instead of rotating the LEDs and circuit there will be a line of LEDs and image will be visible whenever you move your head.
Do you know any instructables or helpful info about this concept?
Thanks.
josekiamora
Re: Static PoV
by adafruit_support_bill on Wed Apr 20, 2011 4:52 am
If I understand you correctly, something like the MiniPOV should do what you are looking for. Unlike the SpokePOV which is triggered by a magnet on each rotation, the MiniPOV is not triggered, It just repeats the pattern over and over.
Re: Static PoV
by mtbf0 on Wed Apr 20, 2011 8:17 am
you're going to hurt your neck.
one thing i've wanted to do is to mount a pov device next to a road so that it can be read from vehicles passing by. don't know if it would work. probably has serious safety issues.
(by the way the minipov has a sensor input that works fine with a hall sensor.)
mtbf0
Re: Static PoV
by josekiamora on Wed Apr 27, 2011 2:33 am
Thank you for your funny answers but I need a serious solution about the frequency and other vital information.
A friend sent me this page but there is nothing that can help me http://letsmakerobots.com/node/22028.
I know that its better to use symmetrical visual...
Thank you in advance.
josekiamora
Re: Static PoV
by mtbf0 on Wed Apr 27, 2011 7:43 am
frequency will be dependent on how fast you move your head and your distance from the wall. i think you'll just have to experiment. hang the gizmo on the wall and shake your head. if all you see is a vertical line of lights, lower the frequency. if the image is too spread out, increase the frequency.
mtbf0
Re: Static PoV
by josekiamora on Fri Apr 29, 2011 2:10 am
and another issue is ; how wide the image shoul be?
josekiamora
