slow usb serial programming on osx... continued
by Tones on Wed Jun 22, 2011 4:26 am
I'm having this exact problem, but the solution outlined in xor's post above does not work for me. Instead of a successful (albeit slow) write, I get this error:
$ make program-makezine
avrdude -p attiny2313 -P /dev/tty.PL2303-0000201A    -c dasa -U flash:w:makezine.hex
avrdude: AVR device not responding
         this check.
avrdude done.  Thank you.
make: *** [program-makezine] Error 1
I'm running OSX 10.6.7, a PL2303 USB/serial adapter, and avrdude v5.10.
It's not a critical problem to fix, but I thought I'd share the bug anyway.
=T=
Tones
Re: mac problem
by adafruit on Wed Jun 22, 2011 2:03 pm
did it ever work at all? we dont understand your question
Re: mac problem
by Tones on Wed Jun 22, 2011 4:47 pm
Ah, oops. I meant to post this as a reply to this post, not as a new topic:
"very slow USB serial programming on Mac OS X"
http://forums.adafruit.com/viewtopic.php?f=11&t=13480
I'm able to write to the avr using avrdude's default settings, but it is incredibly slow. It can take more than a half hour to write to the chip. The "AVR device not responding" error occurs when I try to solve the slowness error by modifying the 'dasa' parameters in the avrdude config file, as recommended here: http://forums.adafruit.com/viewtopic.php?f=11&t=13480#p67533.
Tones
Re: slow usb serial programming on osx... continued
by adafruit on Wed Jun 22, 2011 7:37 pm
ok so it does work but not the speed up? not sure...we didnt write the hack :(
by Tones on Wed Jun 22, 2011 7:41 pm
Yes, that's right -- it works normally (though slowly), it's just the hack that causes actual failure.
So it's not a big deal, just thought I would mention it.
Tones
by xor on Mon Jul 04, 2011 3:52 pm
You write that you modified the dasa parameters in the avrdude config - but did you also do the physical modification (swapping the TXD and RTS line? The easiest way to do this, probably is to make an adapter using a male and a female DB9 connector and some wire.
xor
