MiniPOV + Crosspack + OSX Lion
MiniPOV, MiniPOV2 and MiniPOV3
Postby abyssknight » Tue Aug 30, 2011 11:36 pm
Just got a minipov3 kit from adafruit, and I'm trying to program it under OSX 10.7 Lion. I bought the USB adapter from adafruit, so I believe it is the PL2303. I installed the driver for OSX as directed, but it didn't work on Lion so I installed a patch from http://xbsd.nl/2011/07/pl2303-serial-us ... -lion.html
When I edit /usr/local/CrossPack-AVR/etc/avrdude.conf and add the delay = 2000; line under the dasa programmer, then the command (avrdude -p t2313 -c dasa -P /dev/cu.PL2303-000013FA) errors out with:
syntax error at /usr/local/CrossPack-AVR-20100115/etc/avrdude.conf:650
make: *** [program-alt_leds] Error 1
When I try to program it anyways, a few LEDs light up, but not in sequence like the default program. It looks like TX/RX, but it times out and I get:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
         this check.
avrdude done.  Thank you.
abyssknight
Re: MiniPOV + Crosspack + OSX Lion
Postby adafruit » Wed Aug 31, 2011 1:11 pm
can you verify the minipov is ok by programming it with non-lion?
lion broke -everything- :(
Postby abyssknight » Wed Aug 31, 2011 9:08 pm
It works under Windows XP, so I presume its a Lion thing. Ah well. :)
abyssknight
Return to MiniPOV
New Products [103]
LEDs[109]
Cables[61]
