Minipov not working with Linux
Re: Minipov not working with Linux
by adafruit on Sat Feb 11, 2012 2:23 pm
are you using the version of avrdude we have for download?
by spirou91 on Mon Feb 13, 2012 6:22 am
Yes, I've done all the manipulations as explain on your website.
spirou91
by adafruit on Mon Feb 13, 2012 11:26 am
hmm, not sure what the issue could be. do you have access to a computer with a hardware COM port?
by spirou91 on Mon Feb 13, 2012 4:22 pm
No
I'm going to use an external programmer...
spirou91
by adafruit on Mon Feb 13, 2012 10:00 pm
OK! if you cant get it working, email support@adafruit and we'll refund the not-working stuff, sorry to hear you are having troubles :(
by spirou91 on Tue Feb 14, 2012 12:51 pm
Great!
I will try this on Thursday...
spirou91
by mtbf0 on Fri Feb 17, 2012 12:15 pm
you do have the board powered during programming, right?
no cold joints on the db-9 connector?
i've built a bunch of these as minipovs, minipovs with uv leds, brain machines, rgb brain machines, 4x4x4 led cubes. all programmed with linux. either opensuse or whatever it is that's on my eeepc.
with the led cubes i had to disconnect the leds from the programming lines to program the chip, but never had a problem with single leds on those lines.
mtbf0
