mPOV3 working, but....
by dtownmaker on Thu Feb 16, 2012 3:28 pm
I've got the MiniPOV3 working with a spare laptop direct connect to serial. Programming using repulsor.net assistance has been 50/50.
For some reason, it seems that longer text messages (say 15+ characters) will seem to program correctly (no errors) but the MiniPOV3 will not do anything. Nothing flashes.
Reprogram with a shorter text (8 chars) and it's working again.
Also, a couple of times I have been able to program it but the last couple of characters are not correct. The entire letter is just a couple of pixels.
Could all this be a timing issue I can test through modifying makefile or something else? I read that up to ~500 lines can be programmed and I know I am nowhere near that limit (more like ~100-125 for my largest attempt).
Thanks again for all the support,
MSS <--- :D
dtownmaker
Re: mPOV3 working, but....
by adafruit on Thu Feb 16, 2012 4:46 pm
check the 'long message' file, its called something like "bigtext" :)
by dtownmaker on Thu Feb 16, 2012 8:27 pm
I cannot find that file. There is largeimage - but it is only ~25 lines.
I do not see it in \minipov3\ or in the instructions write-up.
dtownmaker
by mtbf0 on Fri Feb 17, 2012 11:55 am
largeimage is the file you want. it stores the image in program memory, (2k - program size), instead of sram (128 bytes - other data). i would guess that you could get 1k bytes of image in there, but your arm would probably get kind of sore swinging the thing.
mtbf0
