Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
No Hex file created by avr-gcc
by tgmcnaughton on Sun Mar 11, 2012 5:28 am
make.zip
zip contains make.c and Makefile
(3.47 KiB) Downloaded 630 times
I have 2 Minipov3 kits, My OS is WinXP, I'm using a USB adapter
One kit worked perfectly straight away. The other just displayed 10000000 and shifted this value about 1/sec.
I installed avrdude on my winXP machine and flashed the broken miniPOV3 with the make.hex file. It seemed to work fine, and now, both my devices work - to display "Make!"
My problem is this: I'd like to recompile so as to display different words. So, I installed avr-gcc from WinAVR-20100110-install.exe at sourceforge.net.
Now, I'm recompiling make.c using:
avr-gcc -mmcu=attiny2313 -DF_CPU=8000000UL make.c
but it doesn't create a new "make.hex" file.
I'm brand new to AVR microcontrollers, although I have some experience with PICs.
Here's my whole session trying to recompile the stock make.c file:
C:\WinAVR2\POV>
C:\WinAVR2\POV>avr-gcc make.c
In file included from make.c:1:
c:/winavr-20100110/lib/gcc/../../avr/include/avr/io.h:404:6: warning: #warning "device type not defined"
In file included from make.c:3:
c:/winavr-20100110/lib/gcc/../../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>."
In file included from make.c:5:
c:/winavr-20100110/lib/gcc/../../avr/include/util/delay.h:85:3: warning: #warning "F_CPU not defined for <util/delay.h>"
c:/winavr-20100110/lib/gcc/../../avr/include/util/delay.h:90:3: warning: #warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
make.c:99: warning: 'SIG_TIMER1_COMPA' appears to be a misspelled signal handler
make.c: In function 'SIG_TIMER1_COMPA':
make.c:104: error: 'PORTB' undeclared (first use in this function)
make.c:104: error: (Each undeclared identifier is reported only once
make.c:104: error: for each function it appears in.)
make.c: In function 'main':
make.c:111: error: 'DDRB' undeclared (first use in this function)
make.c:131: error: 'TCCR1B' undeclared (first use in this function)
make.c:131: error: 'WGM12' undeclared (first use in this function)
make.c:132: error: 'OCR1A' undeclared (first use in this function)
make.c:134: error: 'TIMSK' undeclared (first use in this function)
make.c:134: error: 'OCIE1A' undeclared (first use in this function)
so then I added -mmcu=attiny2313 to the command line
C:\WinAVR2\POV>
C:\WinAVR2\POV>
C:\WinAVR2\POV>avr-gcc -mmcu=attiny2313 make.c
so then I added -mmcu=attiny2313 and -DF_CPU=8000000UL to the command line
C:\WinAVR2\POV>
C:\WinAVR2\POV>
C:\WinAVR2\POV>
C:\WinAVR2\POV>avr-gcc -mmcu=attiny2313 -DF_CPU=8000000UL make.c
So, as I said above, it seems to run with warnings but no errors, but I don't get a new "make.hex" file.
here's my version info for avr-gcc:
C:\WinAVR2\POV>avr-gcc --version
avr-gcc (WinAVR 20100110) 4.3.3
tgmcnaughton
Re: No Hex file created by avr-gcc
by mtbf0 on Mon Mar 12, 2012 9:54 pm
use the makefile. it will pass all the proper flags to the compiler and get the compiler output converted to a hex file.
try
make program-make
see instructions here.
mtbf0
