Sensor
Re: Sensor
by adafruit_support_bill on Tue Sep 18, 2012 3:53 pm
The standard miniPOV firmware just repeats the image display continuously. With some programming changes, you can use a sensor to trigger the start of the display. For example, the SpokePOV uses a hall-effect sensor & magnet to trigger the start of the display at the same point of each wheel rotation.
Re: Sensor
by edwinp1 on Mon Jan 05, 2015 12:06 pm
Couple questions:
Tactile Alternating Button w/3 Wire Leads(id: 1685)--is this item water
resistant?
PIR Sensor (id: 189)--is there a built-in visual indicator that indicates a
violation when the PIR senses movement?
edwinp1
Re: Sensor
by adafruit_support_bill on Tue Jan 06, 2015 1:32 pm
resistant?
It is not sealed against water.
There is no indicator led on the board.
