Hey there!
I have built a minipov2 on perfboard (front | back) (clickthrough won't work unfortunately, so please shift-reload if you get a 1x1 gif)
Since then I have corrected my build (forgot some resistors, hurray for double checking everything!) and it worked fine.
I got some pretty good results except that when the device was running on battery power it would sometimes reset after displaying a couple of lines. I am using a modified mypov.c.
I noticed that the schematic and the code do not match up... The code uses port B, where the schematic has most of its LEDs connected to port D. I have corrected the code I am using and now it's fine. Was this intentional? Was there a screw-up on my part?
As said, it used to work fine until I tried to run the cycle just once by coding an "exit(0)" or (1), I can't remember which. I uploaded the hex file and now my Tiny isn't responding anymore. Hey! That exit wasn't to be taken so seriously!
I have tried another powersource, this doesn't seem to fix anything. LEDs would blink when the parallel port cable was connected, this has stopped too.
What did I do wrong?
And suddenly it stopped working...
avrdude: AVR device not responding
Double check connections and try again, or use -F to override this check
I bought two (to make sure) new tinies, and will try them out later today.
I was thinking: I have built an iR receiver and it is connected to the serial port. There is a voltage regulator (78L05) that brings any excess voltage from the serial port down to the 5v the iR eye (a TSOP1738) wants to see. There's also a diode (1N4148) that keeps any negative voltage away from the iR eye.
Is it possible that I have burned my first AtTiny up because of too many volts? The chip is certified for voltages up to 5v, that's why I was wondering if it would be safe to build in a voltage regulator like with the iR receiver. Would that make sense? Do I need a diode too?
im pretty sure the attiny can take input as high as 5V even when running at a lower voltage. to be safe you can put in a voltage divider or just a resistor (like 1K or something)
again, there was a mistake in the 'burn fuse' command in the makefile, im pretty sure ive fixed it, you should redownload the code from the site...
POV2 Fuse
Well I attached this 10MHz crystal oscillator
and the appropriate capacitors. Then after I programed in my new fuse values it broke.. I changed your makefile
to
It gave an error saying new value not varified and that was the end of the pov toy. It never responded again, you flip the switch and it doesn't go on.
I tried running burn-fuse with the 0xe4 value again but that didn't work. I tried taking off the oscillator. Still nothing, tried burning the 0xe4 without the oscillator still no response. I'm out of ideas.
lfuse:w:0xe4:m
to
lfuse:w:0xe1:m
