AVR device not responding
MiniPOV4 and previous versions
jpkelly
Post by jpkelly »
I am using a Prolific USB > serial adaptor on Mac OS X 10.9 with the latest Prolific driver (1.5.1)
I have programmed this minipov3 before so I am pretty sure it is assembled correctly.
Not able to get the minipov3 to respond.
Here is the avrdude output:
jp$ avrdude -p t2313 -c dasa -P /dev/tty.usbserial -vvvv -F
avrdude: Version 6.0.1, compiled on Nov 28 2013 at 11:37:09
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/opt/local/etc/avrdude.conf"
         User configuration file is "/Users/jp/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial
         Using Programmer              : dasa
         AVR Part                      : ATtiny2313
         Chip Erase delay              : 9000 us
         PAGEL                         : PD4
         BS2                           : PD6
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        128    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      2048   32     64  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : SERBB
         Description     : serial port banging, reset=rts sck=dtr mosi=txd miso=cts
avrdude: Calibrating delay loop... calibrated to 574 cycles per us
bitbang_cmd(): [ AC 53 00 00 ] [ 00 00 00 00 ]
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATtiny2313 is 1E 91 0A
avrdude done.  Thank you.
adafruit_support_rick
Re: AVR device not responding
This is almost always a problem with connections to the target. The programmer is not seeing any response from the target. Check your connections, use different wires if necessary
Return to “MiniPOV”
