Update the MiniPOV3 with any USB to serial cable
MiniPOV4 and previous versions
opossum
Post by opossum »
Programming the MiniPOV3 firmware requires a USB to serial cable and driver that work with avrdude. Some cables work, others don't, some are not reliable. The firmware presented here offers an alternative to using avrdude to flash the ATtiny2313 chip.
Ordinary async serial communication (aka RS-232) is used to overcome the potential timing problems that occur with avrdude. The bitmap data to be displayed is sent as ASCII text at 9600 bps. The firmware uses self-programming to store the data in the flash program memory.
Here is an example text file...
x LED Test
$7A124
The file must always begin with an 'x'. This is used to calibrate the async serial timing. An optional comment may follow. Each of the following lines contain bitmap info. A <space> or '0' represents a dark LED, most other printable character represent an illuminated LED. A '$' character terminates the bitmap data. Optional timer period and prescale data may immediatly follow the '$'. The first four hex digits are the timer compare value in hex. The fifth hex digit is the timer prescaler index. In this example the prescaler is set to divide by 256 (4) and the timer compare is 31250 (7A12). So the transition period is 8000000 / 256 / 31250 == 1 second. The default is 28001 ( 8000000 / 1 / 10240 == 781.25 transistions per second). Valid prescaler values are 1 to 5 (1==1, 2==8, 3==64, 4=256, 5=1024). For normal POV use the default is usually acceptable.
Sample POV display...
x minipov!
The file must be sent with a <CR> line terminator and a 50 mS delay after each line. The delay allows time for the AVR to program it's flash memory. RTS and DTR must transition from off to on to enter upload mode.
A debug build of the firmware will respond with important debug info. This requires a wire be added to the MiniPOV3 board connecting pin 3 of the ATtiny2313 to pin 2 of the DE9 connector. The async calibration value will be shown after the first line. The address and data will be shown for following lines.
Use these commands to update the firmware. Self programming must be enabled for this firmware to work properly (efuse bit).
Enable self-programming
avrdude -p t2313 -c dasa -P COMx -U efuse:w:0xFE:m
Burn firmware
avrdude -p t2313 -c dasa -P COMx -U flash:w:minipov3asd.hex
Set interval and prescale
avrdude -p t2313 -c dasa -P COMx -U eeprom:w:minipov3asd.eep
Download firmware
opossum
Configuration for HyperTerminal
Post by opossum »
Select File | Properties
Select the port, and then click Configure...
Set to 9600,8,N,1 as shown.
Click the Setting tab and then click ASCII Setup...
Set the line delay to 50 mS.
To upload, click connect, and then use Transfer | Send Text File... to upload the file.
darus67
Post by darus67 »
Sweeeeeeeeeeeet!
I bow in awe of your assembly coding greatness.
Tottiii
Re: Update the MiniPOV3 with any USB to serial cable
Post by Tottiii »
Can you please tell me if the self-programming is done in "cmd" or HyperTerminal?? I tried with cmd but it shows the error message:
avrdude: ser_open<>: can't open device "COMx": ??????????
btw I cannot find attiny2313V-10PU, so I am actually using Attiny2131A-PU instead. Does it matter?
Return to “MiniPOV”
