What is the weight of an assembled miniPOV4 (without batteries)? I see the weight of a SpokePOV (without batteries) is 85g. if you cut it down (at the BMX mark) is it more like 60 (assuming you're removing ~1/4 the LEDs)?
Also, what is the weight of Digital RGB weatherproof LED strip (https://www.adafruit.com/products/306)? Obviously this can be cut down, but is there a weight per foot?
product weight
- adafruit_support_rick
Re: product weight
I make it out to be about 60g/meterjgoldin1 wrote:Also, what is the weight of Digital RGB weatherproof LED strip (https://www.adafruit.com/products/306)?
I have to check on those.jgoldin1 wrote:What is the weight of an assembled miniPOV4 (without batteries)? I see the weight of a SpokePOV (without batteries) is 85g. if you cut it down (at the BMX mark) is it more like 60 (assuming you're removing ~1/4 the LEDs)?
