I have a mini POV3 kit we just finished soldering up but the 2nd LED (in order of the test sequence). This was a father daughter project and my 13 yr.old did the soldering so I'm not sure if we overheated the board. I tried desoldering the LED, but now I think the pad is toast (it won't take solder at all). Is there any way to get a replacement PCB? Or are there other options to get us back on track?
Thanks,
Dave ....
MiniPOV3 board problem
- Franklin97355
Re: MiniPOV3 board problem
Could we see a picture of the board? Perhaps we can give some advice. Take a look at this Soldering Guide for some pointers.
- d_olander
Site tells me the image file is invalid. I tried attaching a JPEG, but now realized the side was too large. Here are the pics front and back. one from the back if after I removed the LED.
- Attachments
- IMG_3573.JPG (124.02 KiB) Viewed 1190 times
- IMG_3571.jpg (142.24 KiB) Viewed 1190 times
- Franklin97355
Test the LED before you do any soldering but if you run the leads to the points on the picture you might be able to get it working.
- Attachments
- 2015-02-01_21h43_04.png (382.35 KiB) Viewed 1187 times
