MiniPOV firmware with a font, longer text
MiniPOV, MiniPOV2 and MiniPOV3
Postby sparr » Fri Dec 05, 2008 1:49 am
I am not sure what use case there might be for 1200 characters of text in a MiniPOV, but if you think of one (or just want really easy text editing) then here is some source for you! It uses a 5x8 font with 64 characters (0-9,A-Z,a-z,space,other). The font and the display text are stored in program memory space.
// original code by LadyAda (and other contributors?)
// modified with font/string support by sparr
// subject to the license of the MiniPOV3 project
#include <avr/io.h>  // this contains all the IO port definitions
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#define TIMER1_PRESCALE_1 1
// store all the font data in program memory (ROM)
// instead of RAM (the default)
const char font[64*5] PROGMEM; // defined below
// store the text to be displayed in ROM too
const char text_string[] PROGMEM = "0123456789 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz ## ";
// special pointers for reading from ROM memory
PGM_P text_string_p PROGMEM = text_string;
PGM_P font_p PROGMEM = font;
#define NUM_ELEM(x) (sizeof (x) / sizeof (*(x)))
int imagesize = NUM_ELEM(text_string)*6-6; // -6 gets rid of the trailing null
// this function is called when timer1 compare matches OCR1A
uint16_t j = 0;
SIGNAL( SIG_TIMER1_COMPA ) {
   uint8_t out;
   if (j >= imagesize)
      j = 0;
   // read one column from ROM
   if(j%6<5) {
      out = pgm_read_byte(text_string_p + j/6); // the character we are on
         font_p + (
            (out>='0'&&out<='9')?(out-'0'):
            (out>='A'&&out<='Z')?(out-'A'+10):
            (out>='a'&&out<='z')?(out-'a'+36):
            (out==' ')?(62):(63)
      ) * 5   + j % 6); // one column from the character
   } else {
      out = 0; // blank column between letters
   PORTB = out; // display the loaded column
   j++;
int main(void) {
   DDRB = 0xFF;         // set all 8 pins on port B to outputs
      desired freq = 400Hz
      clock freq = 8MHz
      8MHz / (400Hz * 2) = 10000
   TCCR1B = (1 << WGM12) | TIMER1_PRESCALE_1;
   OCR1A = (uint16_t)10000;
   TIMSK |= 1 << OCIE1A;   // Output Compare Interrupt Enable (timer 1, OCR1A)
   sei();                        // Set Enable Interrupts
   while (1);
// font inspired by many 5x8 fonts from various sources
const char font[64*5] PROGMEM = {
0b01111110,
0b10100001,
0b10011001,
0b10000101,
0b01111110, //0
0b00000000,
0b10000010,
0b11111111,
0b10000000,
0b00000000, //1
0b10000010,
0b11000001,
0b10100001,
0b10010001,
0b10001110, //2
0b01000010,
0b10000001,
0b10001001,
0b10001001,
0b01110110, //3
0b00011000,
0b00010100,
0b00010010,
0b11111111,
0b00010000, //4
0b01001111,
0b10001001,
0b10001001,
0b10001001,
0b01110001, //5
0b01111110,
0b10001001,
0b10001001,
0b10001001,
0b01110010, //6
0b00000001,
0b11000001,
0b00110001,
0b00001101,
0b00000011, //7
0b01110110,
0b10001001,
0b10001001,
0b10001001,
0b01110110, //8
0b01000110,
0b10001001,
0b10001001,
0b10001001,
0b01111110, //9
0b11111110,
0b00001001,
0b00001001,
0b00001001,
0b11111110, //A
0b11111111,
0b10001001,
0b10001001,
0b10001001,
0b01110110, //B
0b01111110,
0b10000001,
0b10000001,
0b10000001,
0b01000010, //C
0b11111111,
0b10000001,
0b10000001,
0b10000001,
0b01111110, //D
0b11111111,
0b10001001,
0b10001001,
0b10001001,
0b10000001, //E
0b11111111,
0b00001001,
0b00001001,
0b00001001,
0b00000001, //F
0b01111110,
0b10000001,
0b10000001,
0b10010001,
0b11110010, //G
0b11111111,
0b00001000,
0b00001000,
0b00001000,
0b11111111, //H
0b00000000,
0b10000001,
0b11111111,
0b10000001,
0b00000000, //I
0b01100000,
0b10000000,
0b10000001,
0b01111111,
0b00000000, //J
0b11111111,
0b00001000,
0b00010100,
0b00100010,
0b11000001, //K
0b11111111,
0b10000000,
0b10000000,
0b10000000,
0b10000000, //L
0b11111111,
0b00000110,
0b00111000,
0b00000110,
0b11111111, //M
0b11111111,
0b00000110,
0b00011000,
0b01100000,
0b11111111, //N
0b01111110,
0b10000001,
0b10000001,
0b10000001,
0b01111110, //O
0b11111111,
0b00001001,
0b00001001,
0b00001001,
0b00000110, //P
0b01111110,
0b10000001,
0b10100001,
0b01000001,
0b10111110, //Q
0b11111111,
0b00001001,
0b00001001,
0b00011001,
0b11100110, //R
0b01000110,
0b10001001,
0b10001001,
0b10001001,
0b01110010, //S
0b00000001,
0b00000001,
0b11111111,
0b00000001,
0b00000001, //T
0b01111111,
0b10000000,
0b10000000,
0b10000000,
0b01111111, //U
0b00011111,
0b01100000,
0b10000000,
0b01100000,
0b00011111, //V
0b11111111,
0b01100000,
0b00011100,
0b01100000,
0b11111111, //W
0b11000011,
0b00110100,
0b00001000,
0b00110100,
0b11000011, //X
0b00000011,
0b00001100,
0b11110000,
0b00001100,
0b00000011, //Y
0b11000001,
0b10100001,
0b10011001,
0b10000101,
0b10000011, //Z
0b00100000,
0b01010100,
0b01010100,
0b01010100,
0b01111000, //a
0b01111111,
0b01000100,
0b01000100,
0b01000100,
0b00111000, //b
0b00111000,
0b01000100,
0b01000100,
0b01000100,
0b00101000, //c
0b00111000,
0b01000100,
0b01000100,
0b01000100,
0b01111111, //d
0b00111000,
0b01010100,
0b01010100,
0b01010100,
0b01001000, //e
0b00000100,
0b01111110,
0b00000101,
0b00000001,
0b00000000, //f
0b10011000,
0b10100100,
0b10100100,
0b10100100,
0b01111000, //g
0b01111111,
0b00000100,
0b00000100,
0b00000100,
0b01111000, //h
0b00000000,
0b00000000,
0b01111010,
0b00000000,
0b00000000, //i
0b00000000,
0b01000000,
0b10000000,
0b01111010,
0b00000000, //j
0b01111111,
0b00010000,
0b00101000,
0b01000100,
0b00000000, //k
0b00000000,
0b00000000,
0b01111111,
0b00000000,
0b00000000, //l
0b01111000,
0b00000100,
0b00001000,
0b00000100,
0b01111000, //m
0b01111100,
0b00001000,
0b00000100,
0b00000100,
0b01111000, //n
0b00111000,
0b01000100,
0b01000100,
0b01000100,
0b00111000, //o
0b11111100,
0b00100100,
0b00100100,
0b00100100,
0b00011000, //p
0b00011000,
0b00100100,
0b00100100,
0b00100100,
0b11111100, //q
0b01111100,
0b00001000,
0b00000100,
0b00000100,
0b00000100, //r
0b01001000,
0b01010100,
0b01010100,
0b01010100,
0b00100100, //s
0b00000000,
0b00000100,
0b01111111,
0b01000100,
0b00000000, //t
0b00111100,
0b01000000,
0b01000000,
0b01000000,
0b00111100, //u
0b00001100,
0b00110000,
0b01000000,
0b00110000,
0b00001100, //v
0b00111100,
0b01000000,
0b00110000,
0b01000000,
0b00111100, //w
0b01000100,
0b00101000,
0b00010000,
0b00101000,
0b01000100, //x
0b10011100,
0b10100000,
0b10100000,
0b10100000,
0b01111100, //y
0b01000100,
0b01100100,
0b01010100,
0b01001100,
0b01000100, //z
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000, //blank
0b11111111,
0b11111111,
0b11111111,
0b11111111,
0b11111111  //unknown
One odd point... using AVR Studio and WinAVR I was able to make the font array two dimensional and simulate the code successfully. Using avr-gcc I get errors when trying to compile that way, so I just made the array 1D which didn't affect the actual code at all.
Apologies to whomever 0b does not work for. I know that ladyada uses the B8() macros, but they seem like bloat to me (and, to be honest, they highlight weirdly in my editor).
sparr
Re: MiniPOV firmware with a font, longer text
Postby naxxtor » Tue Mar 09, 2010 7:42 pm
Holy topic ressurection!
However, just like to say that this modification is awesome, and we are using it for our custom firmware version for a workshop:
http://tinkersoc.org/wiki/projects:tinkerpov
We made one modification - mainly that instead of reading the string out of PROGMEM it's coming out of EEPROM instead.
Cheers!
naxxtor
Return to MiniPOV
Users browsing this forum: No registered users and 1 guest
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
