I've just assembled a MiniPOV3. When I turn it on, it appears to work AOK- the LEDs cycle as they should.
I'm using an OSX MacBook, attempting to connect via a PL2303 USB-to-serial adapter purchase from the Ladyada store. I've installed the MacPorts version of Avrdude.
I'm attempting to follow the instructions on http://www.ladyada.net/make/minipov3/so ... tml#macosx
First, I plug my minipov into the usb port; the LEDs immediately stop cycling.
Then, I type "avrdude -p t2313 -c dasa -P /dev/cu.usbserial"
The LEDs respond immediately: First, the LED furthest from the chip blinks briefly. Then, the one closest to the chip blinks briefly. Finally, the one furthest from the chip lights up for about 4 seconds. Then the LEDs go out and I receive an error message in my terminal:
avrdude: AVR device not responding
this check.
The Ladyada instructions suggest that I increase the "delay" value in avrdude.conf; but my avrdude.conf does not include a delay value at all. If I add one, avrdude interprets it as a syntax error.
So, any idea what's going wrong here and/or suggestions for diagnosing and fixing it?
My best guess is that I messed up a solder connection somewhere, since I am a solder noob. They all look ok to me, but I could be wrong. If this is the case, what's the best way to find which solder is the culprit?
I'm happy to post pictures of my circuitboard if it will be helpful.
Big thanks!
=T=
