Hi
Got the new POv3 kit and assembled it
when i insert the batteries and turn it on it aint working.. None of the Leds come on or nothing happens..
When i connect it to the PC the the first and the second LEDS blink and then the second stays on for a second or more and then nothing happens.. When ii try to program the LEDS blink and then i get this error
C:\minipovfirmware(2)>make program-minipov
avrdude -p attiny2313 -P com1 -c dasa -U flash:w:minipov.hex
avrdude: AVR device not responding
this check.
avrdude done. Thank you.
make: *** [program-minipov] Error 1
i have checled the solder and everything seems to be fine.
what steps should i follow to get this working...
If needed i will upload the pics
Also on the side note when i run the program all the Leds seemed o be blinking but i still get the error.. In the conf file changed the dealy to 4000
Also ran make burn-fuse just to nmake sure if it works or not
Thanks,
Bob
problem with my new KIT
Re: problem with my new KIT
if it doesnt work at all, as in the LEDs dont come on, then something else is wrong. you should get the LEDs working -first- and THEN try programming it
