I have a nasty problem where all my boards pass initially (work fine) and then some fail at a later date (voltage on the IO pins go to 0.8V and red LED does not flash). Do you have ideas on what the problem is or a temporary fix. Any information will help.
Also I have seen similar problems like this on other forums. Is there any updates on the issue that causes it.
Thank you
Adafruit Audio FX Sound Board fails often
- adafruit_support_rick
Re: Adafruit Audio FX Sound Board fails often
Are these the amplifier versions of the boards? There is a problem with those. We have removed them from the store until we can fix the problem. Meanwhile, we are offering refunds for the Audio FX boards with amplifiers. If those are what you have, please email [email protected] with a link to this thread for a refund.
- chris08
These are not the amplifier version. It's part number is 2220 the link is below.
https://www.adafruit.com/products/2220
- adafruit2
how are you powering it?chris08 wrote:Hi,
Thank you
- chris08
I am powering it through the Vin and GND pins using a controlled power supply set at 3.3V and current limited at 0.5A
- adafruit2
like a bench supply?
- chris08
Yes exactly
- adafruit2
something ive noticed, but i have no idea what it means - when people power from a bench supply, the soundfx's break. but if you use batteries its always ok
- chris08
do you know why that is? It doesn't really make sense to me
- adafruit2
no idea...i know that sounds uninspiring but its just a pattern ive noticed :/
- chris08
Is there any way you can send me a BOM of this board? So I can go through and check parts
- adafruit2
- chris08
Sorry I mean with actual part numbers so for example I can look up a cap and see its rated at 16V
- adafruit2
that we dont have - but every capacitor we have is at least 10V
