Hi, I have made my own minipov2 with the great instructions found at this site. The only problem is I cannot communicate with the ATTINY2313, is there any other programs I can run on XP in a windows shell, or can someone give me some direction. I do not know anything at all about DOS and dont even know how to enter DOS mode ! Also the 2313 is a BANNED chip and I have read that i should blow the fuse ????????????????
Please remember we all had to start somewhere !!!
Programming probs
Thanks for the quick reply. I have been up all night learnig about DOS and I have come quite far but i still have a connection problem. Please can you advise me.
avrdude -p attiny2313 -p lpt1 -c dt006 -u flash:w:minipov.hex
avrdude: AVR device not responding
this check.
avrdude done. Thank you.
I have gone over the hardware several times and everything seems to be in order, is there anything you may be able to suggest !
Thanks..........
[/img][/list]
this check.
Thanks..........
[/img][/list]
The scheme I copied was the one that is on the hardware page, which uses PB0 to PB7 for its output. But I have just figured out how to use eagle and downloaded the files in the download section and these are completely different using PD0 to PD6 and PB0. I think the reason I cannot communicate with the chip is because the program file must be configured to talk to the different ports ????? What do you think !!! Since I cannot even program the Television I think that I will have to make another minipov based on the new schematics.
I am getting the same error
Hi all, I assembled my MiniPOV from kit and have the same message when trying to program. When I power on the MiniPOV all LEDs fire in order. I just can't communicate with the chip.
Any suggestions?[/code]
Fixed!
I tried a different computer and it worked great. Thanks Ladyada! This is too much fun.
Jason
Jason
