troubleshoot VCO: no SAW, only SQUARE
Re: troubleshoot VCO: no SAW, only SQUARE
Postby SubStyler » Fri Mar 11, 2011 2:00 pm
DjunaSaurus wrote:
SubStyler wrote:check the area around C11, C31, C32 (voltages across) Q24, Q25 and the solder joints at S1.
maybe one of your eletcrolytic capacitors is bad or soldered in a wrong direction?
if you try to get saw wave, IC23 is getting hot?
cheers,
SubStyler
I triple checked and everything is soldered right. But I didn't solder C31 and C32 yet (the manual didn't say so), but that normally shouldn't have any effect on the saw right?
you're right. I did not know how far your build has gone at this time. I had the same problem recently and it was a faulty electrolytic cap... C11 to be exactly.
therefore my thought.
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
SubStyler
Postby pattern9 » Sat Dec 15, 2012 1:45 am
This is for reference to the future builders.
I had this problem too.
No saw, only square. R105 gave me a loud pop on the headphones.
After completing the VCF i could hear both waves.
pattern9
Postby monoloco » Thu Apr 04, 2013 4:05 pm
so once again theres a vco completely build
but no saw just a square wave :?
all components triple checked...
...it doesnt feel right to just go on there must be a reason why it doesnt work
any suggestions ??? please!!
"he always had a terrible memory.....to much acid i assume"
monoloco
Postby antto » Thu Apr 04, 2013 4:29 pm
well, the square wave is made out of the sawtooth, which means it most likely works
i'd suggest continue forward and check the waveforms again later :wink:
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Previous
Return to Making x0x
New Products [103]
LEDs[109]
Cables[61]
