hello,
I just made my first runs with my xoxbox..
But the first test wasnt really like a 303 sound i know...
but via part selction i got allready closer to my goal to make it sounding like the 303´s i know...
Ok..they all sound different..but i miss a certain type of smoothness that is common to all of them..
My xoxbox sounded initially harder... not bad.. but not so close as i expected for a circuit that is so close to the original.
I started swapping a few pNP transistors with my old 303 what helped actually a lot..even when the old transistors dont have betas higher then 260.. they sound much more bodyfull and 303ísh muffeld...
I did the reverse check with 733p´s in the old 303... there the sound difference appears not as strong..but is still there...
733ak´s was actually getting closer to the 733ap than the 733p... but that might be beta related..the ak´s have the highest beta of the transistors i ve availible... but that made them only favorable in position Q33 and Q 9...
And even there i would have go for the original used 303 733ap´s when i would have enough availible..
this results in some new questions...
1) is the sound difference related to the transistor type? or is it related to transistor aging? the pnps with the lowest beta in my original and intesivly used 303was found in the filter... with betas around 220... all others was above 250...
is this maybe an aging effekt because the are driven harder in the filter circuit? Or just accidental?
Nothing in the 303 gives indication that the transitors was selcted...
I never considered a single transistor so much as a sound dominating part... and as said within the original 303 the differences are subtile..while in my xoxbox i clearly hear the difference between any transistor..even within the same type and batch..
this especially clear sounds indicates maybe a problem with my xoxbox that has panasonic bc´s for all electorytics.
Maybe they clean out the sound too much opposite to the originals 303 muffly charakter that well can be partially be related to the standart electrolytcs that are used in a huge amount...
I will check that later...
but i expect using the recomended standard electrolytics will give a more original 303 sound.
Another thing i came along is that the foil caps in my 303 and 606 are a different type than the ones recomended in the xoxbox partlist...
they are the transparent green japanese foil caps ..the ones that you usually find in better japanese hif equipment from the 80´s..
As a general experiance from highend preamps i know that better foil caps have a subtile smoother sound...
But however.. i dont know if any 303 has the green transparent foils or just early units...
maybe its mainly a question of aging...especially musical instruments tend to sound smother when they get older..
This applies to electronic instruments aswell.
Maybe the xox box sounds more like a brand new 303?
Regarding transistor selection i can tell that Q8-10 are indeed the most significant PNP´s for beeing selcted
But Q33 is a position that is important aswell... and Q27..especially in combination with Q8 this shapes the sonic character of the xox box quite a bit..
I just got a few original ba 662.. i will see what they do..but after listening to the test audiofiles on the forum i expect them to add another little muffle that brings the whole thing closer to the original 303 sound...
I will post my additional findings...
