check your multimeter to see if its measuring right
measure a new 9v or 1.5v battery
what is the part number on ic20
what are the voltages on ic20
guest wrote:check your multimeter to see if its measuring right
guest wrote:that can go to any good ground point
you can tell the ground pins
by the little cross hairs that connect to the groundplane
also
turn the x0x power off
and measure the resistance between
ground on the mainbaoard and ioboard
it sounds like there is something flakey
its a bit strange that the voltage would go up on the mainboard though
although a bad ground on ic20 would do that
guest wrote:put your meter on resistance mode
its usually marked with an ohm symbol
turn the x0x off
put one probe on a ground point on the mainboard
put the other probe on a ground point on the ioboard
you can also check from the middle pin of ic20
to the ground on the ioboard
to see if its flakey
this is a likely cause of getting 6v on the mainboard
guest wrote:the tact switches arent grounded
use the negative pin of c102 on the mainboard
and the negative pin of c3 on the ioboard
and then check the middle pin of ic20
to the negative pin of c3 on the ioboard
guest wrote:try clipping the middle pin of ic20
back to ground
and see if you get 5v on the mainboard again
if you are still getting 6v on the mainboard
disconnect the mainboard from the ioboard
until you have a steady 5v
as 6v can damage some of the parts
guest wrote:13v on c3 is plenty
in keyboard mode
the note should fade out after a few seconds
does it sound ok when you play a pattern
which leds do not work
all the notes go between 0.44v and 11.52v when pressedyesguest wrote:are you using a 9v AC wallwartall goodplug it in
and let the sound die out
and measure the 12v and 5.333v and 5v rails
make sure they are goodwent through the manual again and test all ok with a scopethen do the headphone test on the vco and vcf
and see if there is still signalif there is
put the x0x in keyboard mode
and measure the gate out
when you press a key
make sure it goes to 12v and back down to 0v
Users browsing this forum: No registered users and 5 guests
