SOLVED (R106 wrong, IC8 bad)
Discuss x0x construction and related issues
Postby mome rath » Wed Jan 05, 2011 9:54 pm
ok
1. can't get more than 6V DC across C5
2. can't get more than 13V DC across C3
3. IC20 getting hot hot hot
4. not getting 5.3 or 12 V for the first two tests in the VCO
5. not getting 5.33 or 12V @ J4 on the main board
briefly got some noise from the waveform switch with headphones
when i disconnect/connect the molex jumper underneath the uController, I sometimes get a single burst of one note
I'm done with these things after this one :evil:
mome rath
Re: nothing working:
Postby guest » Wed Jan 05, 2011 10:02 pm
is this an old one or a new build
disconnect j4 and j3
and see what the powersupply voltages do
you definitely have a short on the 5v line
guest
Postby mome rath » Wed Jan 05, 2011 10:09 pm
guest wrote:is this an old one or a new build
new build
testing PSU voltages again... edit: hold on
just had a good square sound come out after accidentally putting my hand on the waveform switch. then i couldn't replicate it... and IC8 is hot as HELL
mome rath
Postby mome rath » Wed Jan 05, 2011 10:12 pm
ok with j3/j4 removed, I get 12.8 and 13.3 V DC on C3 and C5, respectively
also, the sound off the waveform switch was tunable with the tune pot
mome rath
Postby guest » Wed Jan 05, 2011 10:31 pm
what are the voltages on j4 and ic20
with the jumpers removed
guest
Postby guest » Wed Jan 05, 2011 10:33 pm
and check that ic8 is orientated properly
guest
Postby mome rath » Wed Jan 05, 2011 10:36 pm
the pin designations are looking at the solder side of the power board, left to right
IC20:
pin1: 4.98V
pin2: 0V
pin3: 13V
J4:
pin1: 12V
pin2: 0V
pin3: 5.18V
mome rath
guest wrote:and check that ic8 is orientated properly
yeah, all ICs are in the proper orientation
IC8 only gets hot if pins 1-6 of j3 are connected
mome rath
Postby mome rath » Wed Jan 05, 2011 10:40 pm
with pins 1-6 of j3 disconnected I get the proper 5.3ish and 12v in the VCO test
mome rath
Postby guest » Wed Jan 05, 2011 10:41 pm
what value resistors are you using
for the leds connected to ic8
measure them with a meter
there are either shorts around ic8
or the chip is bad
check the part number on it as well
guest
Postby mome rath » Wed Jan 05, 2011 10:48 pm
guest wrote:what value resistors are you using
or the chip is bad
r263 is a 10k but measures 7.5k
ic8 is a 595 as it should be; I'll try to swap it out
I don't have any LEDs installed yet--those are the only things left out
mome rath
Postby guest » Wed Jan 05, 2011 10:48 pm
after you remove ic8
plug j3 back in
and see what the voltages on ic20 are
guest
Postby mome rath » Wed Jan 05, 2011 11:05 pm
guest wrote:after you remove ic8
plug j3 back in
1: 4.95V
2: 0V
3: 12.28V
mome rath
Postby guest » Wed Jan 05, 2011 11:37 pm
is it all back to working sans ic8
does sound come out
guest
Postby mome rath » Wed Jan 05, 2011 11:40 pm
nothing's working :<
mome rath
Next
Return to Making x0x
Users browsing this forum: No registered users and 4 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
