I am building a TT kit. I know, and have read through the forums, as to the pitfalls of these kits and was careful to look over the boards very carefully to look for bad traces and obvious shorts and found none. In truth, the boards look great and the etching was very clean on all 4 boards (I have 2 kits). So I built the power supply board from the first kit and everything tested fine through that section. Had no hot spots and J4 measured fine with the 5.33v and 12v at the respective pins. I loaded the drivers on my laptop and was able to connect to it via USB and my laptop recognized it properly. Then completed the remainder of the IO board and worked through the VCO section of the first kit as well.
Heres where my issue is. I was going to test the VCO function with my O-scope and thought it best to recheck the J4 voltages before connecting the jumper from J4 to the main board. Now when I measure I get the 5.33v reference at J4 but my 12v is gone. Now IC23 gets warm. Warmer than it should. It takes a minute or so for it to heat up but it gets hot. I tend to keep the power on only as long as it takes me to take measurements and then shut it off before things get hot enough to damage any components. I tried a different IC in IC23 from the other kit and got no change at J4. That said I imagine that there's a short somewhere. I checked through all the previous stages and everything meters fine. The 5.33v is fine, the 5v rail is fine but no 12v.
