Hi everyone, and thanks in advance for any help. I've had an original Adafruit x0x kit sitting around for a couple years and finally got around to building it this last week. Everything seems to be working fine with the sequencer and the synth itself seems to be working as it should with all knobs doing their intended function. The only issue I'm having is with tuning.
The lowest I've been able to get the low C to go with TM5, TM4, and the tuning knob all the way down is about 74 Hz (checking with a multimeter with frequency function). When I put things around center, that lowest C is at around 130 Hz. Also the octave spread between two Cs is only about half of the lower C's frequency, though it gets wider as I get higher up the scale (but still not double).
I'm not really sure where to start looking for a problem. I'm guessing this is a VCO issue, but could some other section be affecting the VCO output? I was very thorough during the build, verifying every resistor with the multimeter before using it and double checking everything, though of course it could be some other faulty component or I simply made a mistake without realizing it.
Any suggestions on what to verify?
