carlibration problem / note out of tune
Discuss x0x construction and related issues
Postby 975262801 » Wed Feb 01, 2012 1:30 am
I have build a few x0xb0x for my friends. I found a common problem on all x0xb0x. The notes goes out of tune on the second day after I done the carlibration. Why? All note is in tune after carlibration. I have not touch anything. Next day when I switch it on again, the note is always goes out of tune. All note shift about one note up or down. Anyone know what cause this problem?
Regards,
phil
975262801
Re: carlibration problem / note out of tune
Postby isak » Wed Feb 01, 2012 7:10 am
maybe its cold :lol:
just kidding, really dont know man, good luck finding the problem and please let us know what was the problem :)
cheers,
Isak E.
isak
Postby guest » Wed Feb 01, 2012 9:00 am
if you retune it
does it stay in tune after that
does your kit have the r100 thermistors in it
can you bring it back into tune
with the tune knob on the front
guest
Postby 975262801 » Thu Feb 02, 2012 6:10 am
guest wrote:if you retune it
Some does and some doesn't.
The one which can be retune, I can easily tune the TM4 back to the right tune(or tune knob at the front). It is weird. I have not touch the x0xb0x at all after the carlibration. Next day woke up in the morning and use a tuner to test the C1 C2 C3 C4, they either goes one note higher or lower. It becomes D1 D2 D3 D4. I know the themistor is sensative to temperature, but it affect the note that much?
However, this is not the worse case. I have some x0xb0x goes out of tune and I am not able to put it back to the right tune. It is very strange. It was 100% working and carlibrate without any problem after I finish all the soldering. All note stay at the right tune. Next day I recheck them, all notes are out of tune. Even I turn TM5 to the max. I am not able to get a exact one octave. Something like C1 to B1 is all I can get for each octave. I never get the octave from C1 to C2 then C3 and C4 in one octave range. It's like the octave range got narrow or somethng. This is so weird. I have a few x0xb0x have the same problem like this. I am sure I use correct resistors/caps/diode/transistor. Soldering on each joint is fine too. There is not many parts in the VCO section. Have u got any idea what cause this strange problem. All these x0xb0x has one common problem, they are all in the right tune when I first finish the soldering and the problem always comes up on the second day when I try to recheck the tune.
975262801
Postby 975262801 » Thu Feb 02, 2012 6:41 am
If this tune problem happen at the very beinging. It could be soldering wrong resistor or caps, but this is not the case. All x0xb0x are carlibrate correct at the right tune. Then I tune it off and havn't touch it until next moring just to re-assure the tuning is correct, and then the note is either goes one note off or gone crazy with a totally wrong narrow octave range.
975262801
Postby isak » Thu Feb 02, 2012 7:13 am
Did you self source the kits or bought them from a dealer?
If from a dealer...who?
isak
Postby guest » Thu Feb 02, 2012 8:56 am
if you have an accurate voltmeter
tune the x0x up
and measure the cv out for a few notes
c1 c2 c3 etc
then when it goes out of tuen again
measure the cv out for those notes again
there are three possible problems
1. your components are not very stable or the tempco resistor is busted
2. your cv is drifting most likely from 5.333v drifting
3. something is overheating inside
guest
Postby antto » Thu Feb 02, 2012 10:57 am
i'm not an expert at all
but my nose tells me something on the board is still hot when you first callibrate.. and cools down the next day
i had such experience when i desoldered C29 and soldered it backwards.. the first audio sample i recorded after soldering had nothing in common with another recording i did a bunch of hours later (without touching any knobs in the mean time..)
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Postby 975262801 » Fri Feb 03, 2012 12:29 am
I self source most of the part myself. I am sure all resistor / IC / capicitor / diode is fine. The only parts I am not sure if it cause the problem is the 1k thermistor and the 2sc1583. The 2sc1583 is some used old parts.
The thermistor is very sensative to temperature. It is acceptable if it goes one note out of tune next day, because I can retune with the tuning knob on the front panel. However, some x0xb0x is seriously off tune with a narrow range. It can not re-tune to one octave even I turn the TM5 to the max. Guess what, I switch on the x0xb0x today and it works fine now. It is so strange. I have two x0xb0x have the same problem. Sometimes goes out of tune with narrow range and sometimes it goes back to normal tune. I agree with you that may be one of the part is unstable in the VCO section. May be sesative to heat or something. Any suggestion which component will cause this problem? There is not many parts on the VCO section. I don't think this problem is caused by resistor / caps / IC.
975262801
Postby guest » Fri Feb 03, 2012 10:00 am
where did you get the thermistors from
and what is the part number
check the cv out just to make sure
guest
Postby 975262801 » Fri Feb 03, 2012 10:55 pm
I bought it from Willzyx Music .
KOA themistors.
PN: LT1/4LT52R102J3100
I have tried the x0xb0x with this drifting problem this morning. The tune has the same problem again. It was working yesterday.
C1 C2 C3 C4 C5 becomes A1 G F# F F today. This is so strange.
975262801
Postby 975262801 » Sat Feb 04, 2012 12:11 am
After I switch on the machine for more than 30 mins, I try to test the tune again. This time, it is kind of back to normal. It is one note off tune. I need to turn the tuning knob at the front panel quite a fair bit to adjust it back to the middle C , but the carlibration is not perfect. What I get on the tuner on each octave is C# C (+20) C (-20) B (+50) C (-50) . This is totally not usable for making music.
975262801
Postby guest » Sat Feb 04, 2012 12:27 am
measure the cv out
just to make sure its the vco
and if the cv doesnt drift
replace the thermistor
its broken
guest
Postby 975262801 » Sat Feb 04, 2012 9:55 pm
1k themistor connects to Q26, the working one is 5.32V and other end is 5.33V. Non working one is 5.25V and 5.32V.
975262801
Postby 975262801 » Sat Feb 04, 2012 11:11 pm
For working unit, the dc reading of pin 7 of IC 11 is :
C d e F g a b c
2.01 2.17 2.33 2.43 2.59 2.75 2.91 3
For the non -working unit, just when I try to test it, it goes back to normal again, so I am not able to check the voltage when it is at the "out of tune status". However, I have check the voltage when it is with the correct tune.
2 2.16 2.33 2.41 2.57 2.77 2.94 3.02
Not much difference with the working unit when it is working. I have no idea why it goes out of tune sometimes.......
975262801
Next
Return to Making x0x
Users browsing this forum: Google [Bot] and 5 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
