experimental scope - poking the x0xb0x
Discuss x0x construction and related issues
guest
Re: experimental scope - poking the x0xb0x
Post by guest »
so the envmod parameter in my equation
can actually go negative
which is what gives that effect
q10 and q11 are biased up to around 3.2v
and envmod can go from 1.8v to 10v at full up
and from 3v to 4.3v at full down
the accent doesnt do this
it always decays back down to 3.2v or so
antto
Post by antto »
i took my multimeter, measured the middle pin of the cutoff pot in my x0x
..when sequencer is not running (and the envelope has decayed out long ago)
when the knob is 0 - there's 4.57V
when it's 1 - 11.85 (i think that's my 12V supply voltage)
so in that formula i guess i should set A=7.28 and B=4.57
then i tryied to measure the middle pin on the envmod pot
when 0 it gives 2.7V
when 1 it gives 0.03V :shock:
but the envelope itself is "discharged" .. i'm not sure how can i measure the peak voltage at the envmod pot (aka when the envelope is peaking)
guest
Post by guest »
youll need to connect up to a scope
to measure the peak values
also
since the effective zero point in that equation is up at a higher voltage
the gains are actually a bit different
the current through r73 and tm3
is the cutoff pot voltage minus the q11 base voltage
the q11 base voltage is at about 3.8v
antto
Post by antto »
i'll try with brute force now
i "parametrized" your equation and my old "approximation" and i'll write a small app which will compare the output of both functions, iteratively, comparing the error
for the coefficients, i'll try random numbers, the algorithm will record the coeffs which give smaller error
i don't expect this to magically find the best coeffs right away, but at best it will get me some small enough error which i'll plot and examine.. then retune the randomizers on each coeff manually and it'll eventually get better and better
guest
Post by guest »
you could probably get a close approximation
by setting accent to 0
and shorting out r61
and setting envmod to 0
then measure the cutoff frequency of the x0x
with cutoff at 0 and at 1
these will give A and B
as the e^() term should stay constant
and reflect coefficents of 0 for C and D
you can also assume E is 0 and see what you get
its just a linear offset
and is probaby pretty close to 0 anyways
you can then keep cutoff constant
and set accent to 1
and see if that gives you D
and then repeat on envmod for C
antto
Post by antto »
so i left the app struggle for an hour (but i watched it, and made changes)
it appears that whatever the value of A is, B should be approximately A*0.125
E almost always made no sense (on each record, E had very different values)
C usually sticks to 0.86
and yeah, right now i don't take the accent into account, i leave it 0
i wanna get the normal envelope ranges at first, then i'll manually figure out how to put accent in there
antto
Post by antto »
i can't seem to make this good enough..
maybe i'm doing it wrong
i *did* modify the equation in order to feed envmod value and envelope value sepparately.. maybe that's wrong
*EDIT*
wait, i had a bug in one place.. now this begins to behave in a way..
now i'm adding my previous approximation of the accent into the equation, guess what happens when i push the envmod .. it appears the exp() is doing some of the voodoo
i'll have to work on it more but it looks promising now
antto
Post by antto »
OMG
it was just a matter of removing my "hacks" from the C13 filter
now i change it's frequency on discharge (aka exactly as if it's a peakfollower)
and it perfectly matches the x0x :shock:
guest, THANK YOU
imma post pictures and sounds after i get back from work
guest
Post by guest »
awesome
im excited to see the pictures
antto
Post by antto »
http://www.box.com/s/e643b6021d543422f0d6 (mp3)
first picture is with envmod=0
second picture is the more problematic case with envmod increased
as you can see, it perfectly matches the behaviour :shock:
guest
Post by guest »
thats great
now im beginning to wonder how compactly
your algorithms can run
in other words
how small of a processor will they run on
can we make a hardware version of your software version
antto
Post by antto »
:mrgreen:
if the sequencer is on a sepparate processor (such as atmega2560 as per the cpu mod)
but my synth relies on floating point math, so a chip with floating point math will be needed
40 leds and a 4x20 LCD
i recently implemented midi sync (with convertion to dinsync) in it too
so it is pretty much like a software x0xb0x
in overall, it works as the x0xb0x
my sequencer outputs 3 signals to the "analog" side
it also handles midi/buttons/leds/eeprom
antto
Post by antto »
so i think it's pretty possible
and i WANT one ;P~
guest
Post by guest »
the arm cortex m4 has floating point
and some friends of mine are making
an arduino compatible development board for it
it runs at 72mhz and is a 32bit machine
so maybe that will work
im just imagining this super small and inexpensive x0x
a pocket acid machine
antto
Post by antto »
but it needs all the knobs and buttons and leds
to be precise..
Venom has 24 buttons (exactly positioned as on the 303) and all of them have a LED (unlike the 303) plus the 16 "bank" leds as on the x0xb0x
tempo and volume pots, bank (16 positions) and mode (12 positions) switches, and the 6 "performance" knobs
ehm, here's how it looks now (it will change a bit, and the LCD is not shown here)
so i think it shouldn't be smaller than the actual 303
Return to “Making x0x”
