Hi all,
I recently discovered I had switched la4140 and ba6110 chip. I've fixed that, but still have numerous problems.
The tempo light/knob works. In keyboard mode, the LEDs light when pressed except for LED31 and 36. LED17 stays lit in keyboard mode.
There is basically no output. Occasionally I do hear a random sound. It is faint though.
The sequencer does not work at all (as far as I can tell): the top LEDs do not light.
When in Pattern Edit mode, the top LEDs will light while going through the patterns, except LED13.
I've been debugging using the analog section reference voltages. The problems I've found so far are:
- Middle pin of Q27 is 0V (should be 5.8V), and the subsequent circuitry connected to it.
- Pin 10 on IC9 is at 5.34V (should be 0V)
- Pin 1 on J5 is at 2.92V (should be 5.96V) and pin 3 is at 5.91V (should be 341mV) -- the pins match between boards, FYI.
The voltages on IC14 and IC15B are correct.
The voltage reading on J4 is correct. While building, the VCO test passed. I didn't do any other tests while building besides those. IC20 gets warm, but not hot.
My only ideas are that Q27 is dead, IC9 is dead, and/or the microcontroller is dead.
