TB-303 :: CV gone bonkers
Discuss x0x construction and related issues
donfuego
Post by donfuego »
Hooked up my old trusty box yesterday only to find it had gotten ill...
What happens is this: As soon as I power it up, the CV (and note pitch) starts from normal and slowly drifts up to 8-9 volts (it probably would keep on if I didn't turn it off at this point). It takes about 30-60 seconds to reach this level but it doesn't drift smoothly though, it goes up and down a bit and occationally drops down several volts.This happens regardless if it is playing a pattern or not.
CV at R90 is NORMAL! I guess it could be the IC11 AN6562, but how can I rule out other possibilities? What about all the transistors, or the R100 or even the diodes?
Luckily I built a x0xb0x a year ago which suffered from pitch problems (I owe big time to guru/hero 'guest' for helping me out) so I'm not all green to this, except this time it's a real 303.
Any thoughts?
Regards
Don
mmm
Re: TB-303 :: CV gone bonkers
Post by mmm »
donfuego wrote:Hooked up my old trusty box yesterday only to find it had gotten ill...
My guess is that indeed IC11 is the culprit here. You could remove D31 and TM5 to make sure (theoretically also IC12 could play a role but I doubt it).
donfuego
Post by donfuego »
Hi guys!
It took me a while to actually pull myself together, source the part and replace it, and wham! as good as new :D
A peculiar thing, it seems like the 6562 had completely died while the 303 been sitting on the shelf for a year or so. Today when powering up, before replacing ic11, there was no sound at all. CV was there (and still goofy) but I could only hear a very faint gate noise when playing, so I was worried that something more had died in there, but it turned out to just be the 6562. Yay!
A late Big Thanks to MMM for the response! :wink:
Return to “Making x0x”
