Grayhill Switch problem (Fixed)
Moderators: altitude, adafruit_support_bill, adafruit, mome rath, phono
by crazycarl on Sat Aug 11, 2012 8:06 pm
Im having a problem with both of the Grayhill rotary switches in that it appears they're acting backwards, flipped polarity (correct term?) For instance when I have it switched to Track DIN Sync its actually in Keyboard mode. Same deal with the Bank selector. I bought the correct switches, Grayhill 25LB22-H, so Im curious what could be causing this?
crazycarl
Re: Grayhill Switch problem
by substyler on Sun Aug 12, 2012 4:04 pm
hi,
maybe just the wrong view.
for example the Mode Select switch: if the flat side is in front of you the x0xb0x is in SYNC OUT mode and if the rounded side is in front of you the machine is in COMPUTER CONTROL mode.
check it out :mrgreen:
cheers,
SubStyler
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
by crazycarl on Mon Aug 13, 2012 12:41 am
Words cannot convey how mental I feel right now, Durr!
crazycarl
